Shopify risk rating incorrect or missing
2 comments
  • Ogg Solutions
    Any updates on this?
    There doesn't seem a clear solution and it's been a month of working through options to resolve this.
    The links in this post have been retired and there's no other information in the Celigo forums about this.
    The advice shopify have been giving are to access orders via a different end point, which isn't an option with the IO APP.
    0
  • David Gollom Strategic Partner
    Top Contributor
    Celigo University Level 4: Legendary
    Answer Pro
    Great Answer
    Engaged
    Any news on this??  Started seeing this recently.  The orders seem to be saved in NetSuite but still throw and error.  maybe you should change the lookup so it doesn't attempt if there's no data?  Appreciate your comment on this issue.
    0
