Required configuration needed to establish the NetSuite connection
Enable SuiteTalk (Web Services), SuiteScript, and SuiteBundler
To enable SuiteTalk (Web Services), SuiteScript, and SuiteBundler in NetSuite, go to Setup > Company > Enable Features. Select SuiteCloud in the sub-menu. The features are displayed. Select the SuiteTalk (Web Services), SuiteScript, and SuiteBundler checkbox and click Save.
NetSuite information needed to establish NetSuite connection with integration app
Celigo’s iPaaS platform integrator.io integration app requires the following information from NetSuite to be entered when configuring NetSuite connection:
- Account ID
- Role ID
- Password
The Role ID is the NetSuite Internal ID of the Role associated with the Account ID (User). To obtain this value you must first know the Account ID associated with the user you are using for this connection. One way to obtain this value within NetSuite is via Setup > Integration > Web Services Preferences > Account ID.
Note: To enable the visibility of internal IDs in NetSuite, go to Home > Set Preferences > General Tab > Set Defaults and select the Show Internal IDs checkbox.
Ways to establish NetSuite Connection with integrator.io
You can establish your NetSuite account connection with integrator.io in the following ways:
- Setup the NetSuite connection with administrator access.
You can choose to assign the Account ID (user) you provide when installing a Celigo’s integration app with the administrator role in the Role ID field. Default internal id for an administrator role in NetSuite is “3”. - Setup the NetSuite connection without administrator access.
If you do not want to associate the administrator role with the Account ID you provide when installing a Celigo’s integration app, you will need to ensure that the Role ID associated with the Account ID has the necessary permissions for the integration app to access the required details from your NetSuite account. The following section provides more details on permission needed to establish NetSuite connection with non-administrator role.
Recommendation: When you use the same login for multiple Celigo integration apps, the concurrency of that login is shared by all the connections. As NetSuite allows you to make only 10 concurrent RESTlet requests at a time per login, we recommend you to use separate NetSuite user login (email and password) for each inetgration app for better throughputs.
Set up permissions for non-administrators roles in NetSuite
Each non-administrator will be able to only access the NetSuite record types that their role permits. Not having adequate role permissions could lead to unwanted errors when executing the data flows. In order for the user to set up, run, and maintain integrations and integration apps in Celigo integrator.io platform with a non-administrator role, you need to provide controlled access using the Permissions option in NetSuite.
To set up controlled access permissions in NetSuite, select Setup > Users/Roles > Manage Roles. The Manage Roles page is displayed. Find the role for which you need to customize the permissions and click Customize. The Role page is displayed.
In the Permissions tab, ensure that the following permissions are enabled for the user:
Section |
Permission |
Level |
For Installation |
Setup |
WebServices |
Full |
Setup |
SuiteScript |
Full |
Setup |
SuiteBundler |
Full |
For Operation |
Setup |
WebServices |
Full |
Setup |
SuiteScript |
Full |
Lists |
Documents and Files |
Full |
Lists |
Vendors |
Full |
Lists |
Perform Search |
Full |
Lists |
Custom Record Entries |
Full |
Lists |
Export Lists |
Full |
Transactions |
Bills |
Full |
Transactions |
Vendor Bill Approvals |
Full |
Transactions |
Purchase Order |
Full |
Transactions |
Deposit |
Full |
Transactions |
Deposit Application |
Full |
Transactions |
Customer Payment |
Full |
