Enable Token-Based Authentication Feature for the NetSuite Account. Setup-> Enable Features-> SuiteCloud
Create a new role (example, Celigo Integration User) with the below permissions
Assign this role (for example, Celigo Integration User) to one of the employees you want to access the connector.
Create a new Integration from the Administrator Role (SetUp-> Integration-> Manage Integration-> New). Note the Consumer Secret and Consumer Key of that integration Record.
Now login to the account with the newly created role.
You should see the Manage Access Tokens link, as shown below.
Click on that and select newly created Integration and save the record. Note the Token ID and Token Secret.
You should be able to save the token-based connection with the Consumer Secret, Consumer Key, Token Secret, and Token ID.
