Issue:
On the Salesforce Quote Lines and Salesforce Opportunity Products, it appears that initially, selecting a discount line item will update the native Salesforce Discount field to coincide with the discount line item's percentage. If someone then changes the discount line item selected, it doesn't update the native Salesforce Discount field after saving, unless the native Salesforce Discount field has been blanked out first.
Resolution:
There is a setting "Do Not Allow Discount Override" under "Opportunity Sync" based on whether we should allow the user to override the Native discount field or not. If this is selected, then whenever the user changes the discount item, it will update the value in the native discount field. If this is not selected, then we allow the user to modify the native discount field and therefore if the user changes the discount item we do not update the discount value.
