Note: We’ve renamed our SmartConnectors to Integration Apps.
Multiple Walmart accounts can be linked to a single NetSuite instance, allowing you to expand your market reach in multiple geographies/languages/currencies. This is an add-on with an additional subscription fee that requires you to purchase one license for each additional Walmart Account that you want to add into the connector. You can contact your account manager to get the required number of licenses.
Connecting an additional Walmart account is a simple task that can be performed in minutes. The Add Walmart Account button available in the data flow Settings panel allows you to connect additional Walmart Account once you have the required license.
Click Add Walmart Account to go to the Set-up section. The following are two steps you need to perform to add an additional account:
- Configure new Walmart Account credentials
The process of configuring new Walmart Account credentials is same as Step 2: Establish a connection with Walmart. To know more about steps involved in configuring new Walmart Account credentials, see Step 2 of Install Walmart - NetSuite Connector.
- Install Account specific components in NetSuite
The process of installing account specific components in NetSuite for an additional account is same as Step 1: Establish a connection with NetSuite. To know more about steps involved in installing account specific components in NetSuite, see Step 1 of Install Walmart - NetSuite Connector.
