Transform Rules is an integrator.io feature that helps you transform your large Export or Import JSON/XML data to a much smaller JSON structure that is much more readable and easier to understand.
You can use this feature to:
- flatten the complex JSON structure.
- provide meaningful field names.
- select a limited set of fields for processing in a flow.
See Also:
For more information on Transformation Rules, please refer to the Transformation Rules Guide attached to this article. You may find it helpful in understanding how the Transform Rules feature actually works in the background.
For detailed examples on transforming data, view the Transformation Rules Guide.
