Skip to main content
Shopify Order stuck on Order Import
1 comment
  • Mina Banoub Strategic Partner
    Engaged
    Great Answer
    Celigo University Level 4: Legendary
    Is there a standard way to deal with this if you do not want to set it to a custom value for all missing matches?
    A good example is digital gift cards. No shipping is required on these items, so I would want to pass a blank value. However, I do not want to set a blank value as the default for all cases where a shipping method match is not found, because that could genuinely be due to a missing or incorrect mapping that needs to be reviewed.
    I could set a handlebar conditional statement to map a blank/null value to 'blank' and add that as a new mapping, but it seems like there should be a more standard approach for a common use case like a digital gift card.
    Best, Mina
    0
