Set up a connection to Salsify
Salsify is a comprehensive solution provider that allows customers to take control of their digital shelves.
This video demonstrates creating a Salsify connection.
Setting
Instructions
Name your connection *
API type *
Choose the API type, depending on the Salsify API type you're connecting to. The settings then become specific to the selected API type.
API type: Salsify: V1
Setting
Instructions
Organization ID *
Enter your organization ID.
For example, if your Salsify account is located at
https://app.salsify.com/app/orgs/s-a3326-0ac-4de-972-c436063303cf/productsthen s-a3326-0ac-4de-972-c436063303cfis the organization ID.
API key *
Enter your Salsify API key.
dataLoad.svg​​ How to retrieve API key
API type: Salsify: Versionless
Setting
Instructions
Organization ID *
API key *
  1. Sign in to your Salsify developers account.
  2. Navigate to My profile > API access.
  3. Click Show API key. The Get API key window appears.
  4. Enter your password. Click Ok.
  5. Copy API key.
Additional references
