integrator.io can automatically suggest destination field mappings that you have not yet added. For example, if firstName
has already been mapped in the destination field, then Auto-map will add field mappings for destination fields except for the firstName
field. The suggestions are based on common mapping configurations between the two applications and how frequently these field mappings are successfully configured by integrator.io users.
Click Auto-map fields BETA to allow integrator.io to suggest field mappings that have not already been applied to your Snowflake import.
The suggested fields display in the New mappings section underneath any fields you have already mapped manually. Any fields you have manually mapped remain unaffected, but you can also modify or delete any of the new fields.
