For non-technical users unfamiliar with integrator.io's core functionality, AI-generated descriptions and summaries offer a comprehensible insight into the business logic of resources. Celigo AI can generate plain language descriptions for exports, imports, and flows. AI-generated descriptions and summaries provide non-technical users with a comprehensive insight into the business logic of your resources.
Celigo AI-generated descriptions serve as a reference to understand workflows or integrations, simplify the troubleshooting process, and facilitate a better understanding of existing setups. AI-generated resource descriptions can help you:
Easily understand the logic of a resource created months ago allowing you to avoid tedious configuration checks.
Seamlessly transfer management of integrations when a team member departs without dependencies on manual documentation.
Provide leadership teams with high-level summaries without diving into intricate details.
Transfer integrations to and from services and partner teams smoothly, maintaining confidence that users with varying degrees of platform knowledge will easily understand the resources.
You can view the AI-generated descriptions in the English language for flows , flow steps exports , and imports.
On the AI-generated resource descriptions window, the scroll position will persist (within the Flow builder, imports, and exports) till you move out of the page. On page refresh, the descriptions do not persist on the Flow group, Flow list, Flow step, Import list, and Export list pages.
The description summary may vary slightly each time you access the resource descriptions, so copy and save useful information in the description.
AI-generated descriptions might sometimes be inaccurate, so verify accuracy before using the description.
AI-generated descriptions are available for transformations, hooks, mappings, and branches. Click the Celigo AI icon to see summaries and descriptions of various components:
On the Flow Builder page, next to the flow name.
Inside an integration, in the Flows tab, for each flow
Below Flow Group, for the Flow list
When you add a flow step, on the Create source window, the AI-generated description is available next to the flow step.
For exports and imports, click the Edit icon to have your Description for the resource saved for other users to see. By default, the description window is expanded.
You can find the export descriptions at:
Flow Builder page > Edit Export window
Left menu > Resources > Exports
Flow Builder page > Edit Import window
Left menu > Resources > Imports
It takes a while to generate the descriptions. When you’re viewing the description for the first time, you have to wait for a few seconds.
Celigo AI resource descriptions allow you to:
copy the complete description (or a selected part of it).
By default, the refresh option is disabled until you update any resource. After you update the resource, click Refresh, to view the initial description and summary.
collapse the description window
close the description window
To provide feedback, click thumbs up or thumbs down below each description to convey whether Celigo AI's response was beneficial.
