Install the Magento 2 - NetSuite integration app
Important:
  • New installations: Install the Celigo SuiteApp (integrator.io SuiteApp) when prompted, and then click Verify to continue. You do not need to install the integrator.io SuiteBundle.
  • Existing installations: Integrations that currently use the integrator.io SuiteBundle continue to work.
The Magento 2 -NetSuite integration app helps online retailers combine the powerful Magento 2 online marketplace platform with the proven back-office features of NetSuite and keep the orders, customers, fulfillments, pricing & inventory levels in sync.
Before you install the integration app
Before you install the Magento 2 - NetSuite integration app, perform the following:
  1. Install the Celigo SuiteApp (integrator.io SuiteApp).
  2. Install Magento 2 Bundle in NetSuite.
Install Magento 2 bundle in NetSuite
  1. In NetSuite, go to Customization > SuiteBundler > Search & Install Bundles.
  2. On the "Search & Install Bundles" page, in the Keywords field, enter Celigo Magento 2 Connector (bundle name) or 119234(bundle ID).
  3. Click Search.
  4. Click Celigo Magento 2 Connector.
  5. On the "Bundle Details" page, click Install.
  6. On the permission window, read through and click OK.
  7. Your bundle will now be installed and you can find the same in the Search & Installed Bundles page ( Customization > SuiteBundler > Search & Install Bundles > List ).
Configure your NetSuite account
Enable Token-Based authentication in your NetSuite account
  1. Log in to your NetSuite account as an Administrator.
  2. Go to Setup > Company > Enable Features.
  3. On the "Enable Features" page, click SuiteCloud.
  4. In the Manage Authentication section, check the TOKEN-BASED AUTHENTICATION checkbox.
  5. Click Save.
Create a custom role in NetSuite
  1. In NetSuite, go to Setup > Users/Roles > Manage Roles.
  2. On the "Manage Roles" page, next to the "Celigo eTail SmartConnectors" role, click Customize .
  3. On the "Role" page, in the Name field, enter a different name to c lone the role.
  4. In the "Permissions" tab, configure the permissions as per your business needs as needed.
  5. Click Save.
Select NetSuite user and assign a role
Select the NetSuite user account that will be used to connect your Magento 2 SmartConnector.
  1. In NetSuite, go to Setup > Users/Roles > Manage Users.
  2. On the "Manage Users" page, click on the appropriate user to connect your Magento 2 integration app.
  3. On the selected Employee page, click Edit.
  4. Go to Access tab > Roles sub-tab.
  5. Select the role that was created in the "Create a custom role in NetSuite" step.
  6. Click Save.
Generate NetSuite access tokens
  1. In NetSuite, go to Setup > Users/Roles > Access Tokens > New.
  2. In the APPLICATION NAME drop-down box, select eTail Connectors (Token-Based Auth).
  3. In the USER drop-down list box, select the user name that you have edited in the previous step.
  4. In the ROLE drop-down list box, select the role that was assigned to the user.
  5. The TOKEN NAME populates automatically. Modify the name as needed.
  6. Click Save.
  7. Token ID & Token Secret will be displayed. Save the tokens in a place where you can copy it into your Celigo connection as described in the next section.
Install Magento 2 - NetSuite Integration App
Prerequisite: Ensure you have a valid subscription license to install the integration app.
If you're installing the Magento 2 - NetSuite integration app on the Magento 2.4.1 version and above, you have to configure your Magento 2 connection using token-based authentication to access the Magento Admin UI from all devices. For more information, refer to Authorize Magento 2 integration app connection using token-based authentication.
  1. Log in to your integrator.io account.
  2. In the left pane, click Marketplace.
  3. On the Marketplace page, click Magento 2.
    Note: If you see Contact Sales instead of Install, contact your Account Executive to check the status of your integration app license.
  4. Click Install.
  5. On the "My Integrations" page, you can now find the Magento 2 - NetSuite integration app. On the tile, click Continue setup.
  6. Configure your connections:
  7. For the NetSuite connection, refer here.
  8. For the NetSuite component, click Install to install the Celigo SuiteApp. Log in to NetSuite when prompted, complete the installation, and then click Verify.
  9. For the Magento 2 connection, refer here.
  10. As you have already installed the Magento 2 bundle, click Install.
  11. For the Celigo SuiteApp (integrator.io SuiteApp), the Installed status will appear automatically if you have already installed the integrator.io SuiteApp. If you have not installed the integrator.io SuiteApp, click Install to install the Celigo SuiteApp. Log in to NetSuite when prompted, complete the installation, and then click Verify.
  12. For Magento 2 Bundle, click Verify Now. This is because you installed the Magento 2 bundle.
    Note: If you're seeing the Click to Install link, click the link and this will open the NetSuite login page. Log in to NetSuite with your NetSuite credentials, and the Click to Install link will automatically convert to the Verify Now link. Now click Verify Now.
  13. For the Magento Extension, Install Magento 2 Extension.
    Note: Whenever you refresh your sandbox environment in NetSuite, it is recommended to uninstall the integration app and reinstall it.
Install the Magento 2 extension
To install the Magento 2 Extension in your Magento instance, see Install an extension.
IMPORTANT: The Celigo Magento2 - NetSuite integration app extension is certified with Magento2 version 2.4.6 and is now available in the Magento marketplace for you to upgrade. The integration flows work seamlessly even after upgrading to the latest Magento2 version 2.4.6. For more information, see Magento2 - NetSuite integration app compatibility with Magento version 2.4.6 update.
  1. Purchase the free Celigo "NetSuite Connector" (Magento 2 extension) from the Magento Marketplace. You will receive a zip file.
  2. Upload the zip file to your Magento server using the instructions below:
    Note: Refer to the Magento extension install instructions here.
    1. Ensure you have FTP Access and SSH or command access for your Magento server FTP.
    2. Log into the FTP of your Magento server and navigate to the "Magento" directory.
    3. Go to the "app" folder and check if there is any "code" folder. If not, create a folder named "code".
    4. Go inside the "code" folder and create a new folder named "Celigo". Then, go inside the "Celigo" folder and similarly, create a folder named "Magento2NetSuiteConnector".
    5. Unzip the above zip file here.
    6. Then open the ssh/command prompt on your Magento server, go to the Magento install directory, and run the following commands
      1. php bin/magento setup: mode developer
      2. php bin/magento module:enable Celigo_Magento2NetSuiteConnector
      3. php bin/magento setup: upgrade
      4. php bin/magento cache: clean
      5. php bin/magento setup: mode production
