All NetSuite to JIRA data flows provide an option to define a qualification criteria. By using this feature you can define complex logic based on which records are picked up from NetSuite synced to JIRA. e.g. using the qualification criteria you can instruct the Connector to only consider NetSuite records with a field having a particular value. The Qualification criteria option can be used to define multiple business rules.
The following screens depict an example. To activate the 'Settings' function (gear icon), the data flow must first be turned on.
The following 'Settings' window is displayed. Select Qualification Criteria.
You can define multiple business rules.
