Postscript is a text message marketing platform designed specifically for e-commerce businesses. It enables companies to create, launch, and manage SMS marketing campaigns.
Setting | Instructions |
Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
API key * |
Enter your Postscript public key. |
X-Postscript-shop-token * |
Enter your Postscript private key. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see token auth universal connector documentation.
How to retrieve the public key and private key
- Sign in to your Postscript account.
- From the left panel, select your Shop.
- Navigate to API.
- Click Create security key pair.
- Click Yes.
- Copy the Public key.
- Copy the Private key.
