Supported Reviews.io APIs
When you configure an export, import, or another type of flow step using the form view designed for the Reviews.io connector, the following API operations are supported:
Note: You can also create a composite endpoint for this application. For more information, see Application-specific (simple) forms.
Resource API endpoint Export Import
Company review invitations List company invitations X
Queue company SMS invitation   X
Edit company invitations   X
Product review invitations List product invitations X
Queue product and company invitations   X
Queue product SMS invitation   X
Edit product invitations   X
Review nuggets Retrieve review nuggets X
Review tagging Tag a company review   X
Tag a product review   X
Reviews and questions Retrieve product ratings X
Retrieve basic review statistics X
Create a new question   X
Create a new product review   X
Retrieve reviews and questions   X
Surveys Retrieve surveys X
Retrieve survey responses X
Unsubscribe users Unsubscribe a user from Reviews.io   X
Retrieve unsubscribed users   X
User generated content Retrieve user generated Content X
Webhooks List all webhooks X
Add a review submitted webhook   X
Remove a review submitted webhook   X
