AbuseIPDB service allows users to report and check IP addresses for malicious activity. It helps combat the spread of hackers, spammers, and abusive activity on the internet.
API key * |
Enter your AbuseIPDB API key. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s API key safe. When editing this form later, you must enter this token again; it is stored only when the connection is saved and never displayed as text. |
Sign in to your AbuseIPDB account.
Navigate to Profile > Accounts > API.
Click Create key.
Enter a Name.
Click Create.
Copy the API key.
