Klaviyo documentation: API guide , Authentication
Start establishing a connection to Klaviyo in either of the following ways:
From the Resources menu, select Connections. Then, click + Create connection at the top right.
– or –
While working in a new or existing integration, you can add an application to a flow by clicking a source or destination. In the resulting Application list, select Klaviyo. Then, click the plus sign (+) to the right of Connection to edit the settings.
Name: Required: Name the connection.
API key: Required: Enter the API key. Use the following steps to get an API key:
Log in to your Klaviyo account.
Click Account.
Under Settings, click API Keys to get the API key.
