Klaviyo is a marketing automation platform designed to help businesses grow by leveraging data-driven insights to create personalized and targeted email and SMS marketing campaigns.
Setting | Instructions |
Name your connection * | Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account. |
API type * |
Choose your Klaviyo API type:
Private key * |
Enter your Klaviyo private key. |
Public key * |
Enter your Klaviyo public key. |
Revision * | Enter your Klaviyo API endpoint version in YYYY-MM-DD format. |
Tip: This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see Token auth universal connector documentation.
How to retrieve the private key and public key
- Sign in to your Klaviyo account.
- Navigate to Account > Settings > API keys.
- Copy the Public API key.
- Click Create Private API key.
- Enter a Name.
- Select the Scopes.
- Copy the Private API key.
