Set up a connection to AAFES
AAFES is the Army & Air Force Exchange Service, the retailing service on Army and Air Force installations worldwide.
Start establishing a connection to AAFES in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select AAFES AS2 or AAFES FTP.
Supported AAFES X12 documents
The supported X12 document types for the AAFES trading partner are listed below:
  • Purchase order - 850
  • Purchase order change request - 860
  • Invoice - 810
  • Purchase order acknowledgement - 855
  • Ship notice - 856
  • Application advice - 824
