Set up a connection to BJs Wholesale
Start establishing a connection to BJs Wholesale in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select BJs Wholesale AS2 or BJs Wholesale FTP.
Supported BJs Wholesale X12 documents
The supported X12 document types for the BJs Wholesale trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Ship notice - 856
