Set up a connection to Costco
Start establishing a connection to Costco in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select Costco AS2 or Costco FTP.
Supported Costco X12 documents
The supported X12 document types for the Costco trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Purchase order acknowledgement - 855
