Start establishing a connection to Target Drop Ship in either of the following ways:
– or –
– or –
In the resulting EDI trading partners list, select Target Drop Ship AS2 or Target Drop Ship FTP.
The supported X12 document types for the Target Drop Ship trading partner are listed below:
Purchase order - 850
Purchase order change request - 860
Purchase order acknowledgement - 855
Purchase order change acknowledgement/request - 865
Invoice - 810
Ship notice - 856
Inventory Inquiry/ Advice - 846
