Set up a connection to Ace Hardware
Start establishing a connection to Ace Hardware in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select Ace Hardware AS2 or Ace Hardware FTP.
Supported Ace Hardware X12 documents
The supported X12 document types for the Ace Hardware trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Ship notice - 856
  • Inventory Inquiry/Advice - 864
  • Credit/Debit Adjustment - 812
  • Remittance Advice document - 820
