Kohls is a leading omnichannel retailer (a department store retail chain), operated by Kohl's Corporation.
Start establishing a connection to Kohls in either of the following ways:
– or –
– or –
In the resulting EDI trading partners list, select Kohls AS2 or Kohls FTP.
