Set up a connection to Neiman Marcus
Start establishing a connection to Neiman Marcus in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select Neiman Marcus AS2 or  Neiman Marcus FTP.
Supported Neiman Marcus X12 documents
The supported X12 document types for the Neiman Marcus trading partner are listed below:
  • Purchase order - 850
  • Purchase order change request - 860
  • Invoice - 810
  • Ship notice - 856
