Set up a connection to Walmart
Start establishing a connection to Walmart in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    – or –
    – or –
In the resulting EDI trading partners list, select Walmart AS2 or Walmart FTP.
Supported Walmart X12 documents
The supported X12 document types for the Walmart US (Drop Ship Vendors) trading partner are listed below:
  • Purchase order - 850
  • Purchase order acknowledgment - 855
  • Purchase order change request - 860
