Download the Postman schemas
This article covers the schemas used to build your HTTP connector using the provided Postman collection. There are three schemas which must be used in the presented order. Learn more about the concepts behind creating an HTTP connector.
Warning
You cannot create a new resource or endpoint without a connector! You must create the connector, then the resource, and finally the endpoints. After, you can add as many resources or endpoints as you want.
Click on the POST
call for each schema in Postman to get copies of the request bodies. Remember to remove the examples and connection IDs!
You're simply using existing connector options in the Celigo platform to build the connector. If you're unsure what a field is used for, learn more about Custom forms and common form fields. Note that the list of common form fields is not conclusive. It simply lists the most common fields.
This schema allows you to create an HTTP connector.
{ "tempId": "toasttab_tempId", "name": "Toast 1", "published": false, "helpURL": "https://docs.celigo.com/hc/en-us/articles/25126630529947-Set-up-a-connection-to-Toast", "baseURIs": [ "https://{{{connection.settings.domain}}}" ], "disableAutoLinking": true, "versioning": {}, "versions": [ { "tempId": "toasttab_version_tempId", "name": "1.0", "baseURIs": [], "published": true } ], "apis": [], "supportedBy": { "export": { "preConfiguredFields": [ { "path": "successMediaType", "values": [ "json" ] }, { "path": "errorMediaType", "values": [ "json" ] }, { "path": "requestMediaType", "values": [ "json" ] }, { "path": "headers", "values": [ [ { "name": "Toast-Restaurant-External-ID", "value": "{{{connection.settings.toastRestaurantExternalID}}}" } ] ] } ] }, "import": { "preConfiguredFields": [ { "path": "successMediaType", "values": [ "json" ] }, { "path": "errorMediaType", "values": [ "json" ] }, { "path": "requestMediaType", "values": [ "json" ] }, { "path": "headers", "values": [ [ { "name": "Toast-Restaurant-External-ID", "value": "{{{connection.settings.toastRestaurantExternalID}}}" } ] ] } ] }, "connection": { "preConfiguredFields": [ { "path": "type", "values": [ "http" ] }, { "path": "http.mediaType", "values": [ "json" ] }, { "path": "http.ping.relativeURI", "values": [ "/authentication/v1/authentication/login" ] }, { "path": "http.ping.method", "values": [ "POST" ] }, { "path": "http.ping.body", "values": [ "{\n \"clientId\": \"{{{connection.http.unencrypted.client_id}}}\",\n \"clientSecret\": \"{{{connection.http.encrypted.client_secret}}}\",\n \"userAccessType\": \"TOAST_MACHINE_CLIENT\"\n}" ] }, { "path": "http.headers", "values": [ [ { "name": "content-type", "value": "application/json" }, { "name": "Toast-Restaurant-External-ID", "value": "{{{connection.settings.toastRestaurantExternalID}}}" } ] ] }, { "path": "http.auth.type", "values": ["token"] }, { "path": "http.auth.token.token", "values": ["x"] }, { "path": "http.auth.token.location", "values": ["header"] }, { "path": "http.auth.token.headerName", "values": ["Authorization"] }, { "path": "http.auth.token.scheme", "values": ["Bearer"] }, { "path": "configureTokenRefresh", "values": [true] }, { "path": "http.auth.token.refreshMethod", "values": ["POST"] }, { "path": "http.auth.token.refreshRelativeURI", "values": [ "https://{{{connection.settings.domain}}}/authentication/v1/authentication/login" ] }, { "path": "http.auth.token.refreshBody", "values": [ "{\n \"clientId\": \"{{{connection.http.unencrypted.client_id}}}\",\n \"clientSecret\": \"{{{connection.http.encrypted.client_secret}}}\",\n \"userAccessType\": \"TOAST_MACHINE_CLIENT\"\n}" ] }, { "path": "http.auth.token.refreshTokenPath", "values": ["token.accessToken"] }, { "path": "http.auth.token.refreshTokenLocation", "values": ["body"] }, { "path": "http.auth.token.refreshToken", "values": ["x"] }, { "path": "http.encryptedFields", "values": [ { "id": "client_secret", "name": "client_secret", "type": "text", "inputType": "client_secret", "label": "Client secret", "description": "Note: for security reasons this field must always be re-entered.", "required": true, "helpText": "" } ] }, { "path": "http.unencryptedFields", "values": [ { "id": "client_id", "name": "client_id", "type": "text", "label": "Client ID", "required": true, "helpText": "Enter your Bloomfire account email ID." } ] }, { "path": "settingsForm", "values": [ { "fieldMap": { "domain": { "id": "domain", "name": "domain", "type": "text", "label": "Domain", "required": true, "displayAfter": "connection.application", "helpText": "Enter your Toast account domain. For example, if your account URL is https://test.toasttab.com, then test.toasttab.com is the domain." }, "toastRestaurantExternalID": { "id": "toastRestaurantExternalID", "name": "toastRestaurantExternalID", "type": "text", "label": "Toast restaurant external ID", "required": true, "displayAfter": "connection.settings.domain", "helpText": "Enter your Toast restaurant external ID provided by the Toast <a href='https://central.toasttab.com/s/contact-support'>support</a> team." } }, "layout": { "fields": [ "domain", "toastRestaurantExternalID" ] } } ] } ], "fieldsUserMustSet": [ { "path": "settings.domain" }, { "path": "settings.toastRestaurantExternalID" }, { "path": "http.unencrypted.client_id" }, { "path": "http.encrypted.client_secret" } ] } } }
The request body is as follows:
Key |
Definition |
Name of the application. |
This field must always remain false. |
The application's base URL. It's an array object field that can hold multiple base URIs, but by default, it will show the very first URI from the array. It can be mentioned globally, locally, and inside the version array object. |
Add a link to your own connection guide. |
Defines how the versioning is done for this application. See the versioning subSchema for more. |
An array of different versions applicable for the connector/api. The version is explained in the Versions subSchema. |
If the connector has multiple independent APIs, a list of all APIs should be defined. This should be an array. For example, Shopify has Partner APIs and Payment APIs. Both are mutually exclusive APIs designed for different purposes. See the APIs subSchema for more. |
Configurations and settings applicable for this connector. See the supportedBy subSchema for more. |
{ location: [uri, query_parameter, header] headerName: '' queryParameterName: '' }
Key |
Definition |
Determines where your versioning will be mentioned: |
If the version is not mentioned in the URI, it can be in the header, but you must provide a header name. |
If the version is not mentioned in the URI or header, it can be a query parameter, but you must provide a query parameter name. |
Key |
Definition |
The application's base URL is an array object field that can hold multiple base URIs, but by default, it will show the very first URI from the array. It can also be mentioned globally and locally inside the version array object as a requirement. |
Relative to your connector’s version. |
For Export
and Import
subschemas:
"supportedBy": {
"export": {
"values": [
"json"
"values": [
"json"
"values": [
"json"
"path": "headers",
"values": [
"supportedBy": {
"import": {
"values": [
"json"
"values": [
"json"
"values": [
"json"
"path": "headers",
"values": [
Key |
Definition |
Requirements that remain the same regardless of who created the connection or when it was created. For example, the application’s Base URI (if fixed) or the authentication type. Learn more about preConfiguredFields. |
Each path will be used to provide a location that we want to pre-configure. |
Each value will contain one or more details that you want to predefine for a specific location or field. By providing a path, the value can be assigned to any particular location or field. |
Fields under this array object are mandatory, and users must provide input. Learn more about fieldsUserMustSet. |
For Connection
subschemas:
"connection": {
"path": "type",
"values": [
"http"
"values": [
"json"
"values": [
"values": [
"POST"
"values": [
"values": [
"values": ["token"]
"values": ["x"]
"values": [true]
"values": ["POST"]
"values": [
"values": [
"values": ["body"]
"values": ["x"]
"values": [
"type": "text",
"required": true,
"helpText": ""
"values": [
"id": "client_id",
"type": "text",
"required": true,
"values": [
"fieldMap": {
"domain": {
"id": "domain",
"name": "domain",
"type": "text",
"label": "Domain",
"required": true,
"type": "text",
"required": true,
"layout": {
"fields": [
"domain",
Key |
Definition |
This schema allows you to create an HTTP resource.
{ "tempId": "audit_trail", "name": "AuditTrail", "published": true, "_httpConnectorId": "664e075a780d6ecff6f196eb", "_versionIds": ["664e075a780d6ecff6f196ec"], "resourceFields": [ { "id": "text", "dataType": "string" }, { "id": "objects", "dataType": "objectarray", "resourceFields": [ { "id": "type", "dataType": "string" }, { "id": "ids", "dataType": "stringarray" } ] } ] }
Key |
Definition |
A unique identifier for each resource, later used to render the endpoints under respective resources. |
Name of the resource. |
An array field that will provide the version IDs generated after making the |
Unique connector ID from the NoteThe |
This is an array object field, which will be used to define the structure of the request body for a resource as per the API Doc or to produce the mapping dropdown. |
Unique identifier of the resource field. |
Defines the datatype (Object, ArrayObject, String, etc.). |
Supported resource fields. |
This schema allows you to create an HTTP endpoint.
{ "tempId": "get_api_members_system_api_members_get", "name": "Get API members", "description": "", "published": true, "_httpConnectorResourceIds": [ "6540a7540081a9eca616dd54" ], "method": "GET", "relativeURI": "/system/apiMembers?page={{export.http.paging.page}}", "queryParameters": [ { "name": "conditions", "description": "conditions", "required": false, "dataType": "input", "label": "conditions" }, { "name": "orderBy", "description": "orderBy", "required": false, "dataType": "input", "label": "orderBy" }, { "name": "childconditions", "description": "childconditions", "required": false, "dataType": "input", "label": "childconditions" }, { "name": "customfieldconditions", "description": "customfieldconditions", "required": false, "dataType": "input", "label": "customfieldconditions" }, { "name": "page", "description": "page", "required": false, "dataType": "number", "label": "page" }, { "name": "pageSize", "description": "pageSize", "required": false, "dataType": "number", "label": "pageSize" }, { "name": "pageId", "description": "pageId", "required": false, "dataType": "number", "label": "pageId" } ], "pathParameters": [], "supportedBy": { "type": "export", "preConfiguredFields": [], "fieldsUserMustSet": [], "fieldsToUnset": [], "lookupToIdentifyExisting": {} } }
Key |
Definition |
Endpoint name. |
Description of the endpoint. |
This field must always remain |
Unique resource ID from the httpconnectorresources API response after making the API call. NoteThe |
Method of the endpoint. |
Relative URL of the endpoint. |
For Export
subschemas:
Key |
Definition |
For Import
subschemas:
Key |
Definition |
For Connection
subschemas:
Key |
Definition |
