When you configure an export, import, or lookup using the form view designed for the Oracle Textura connector, the following API operations are supported:
You can also create a composite endpoint for this application. For more information, see Application-specific (simple) forms.
Resource |
Endpoint |
Export |
Import |
Change orders |
Subcontract change orders |
X |
Subcontract change orders audit |
X |
Compliance requirements |
X |
Compliance requirements audit |
X |
Documents |
Document metadata request |
X |
Document file request |
X |
Documents request |
X |
Documents response |
X |
ERP records |
ERP records |
X |
ERP records audit |
X |
Invoice rejections |
Invoice rejections request |
X |
Invoice rejections response |
X |
Invoices |
Owner invoices |
X |
Owner invoices audit |
X |
Invoices request |
X |
Invoices response |
X |
Payments |
Cash receipts |
X |
Cash receipts audit |
X |
Owner fundings |
X |
Owner fundings audit |
X |
Off-system payments |
X |
Off-system payments audit |
X |
Payments request |
X |
Payments response |
X |
Prime change orders |
X |
Prime change orders audit |
X |
Projects |
Projects |
X |
Projects audit |
X |
Owner projects request |
X |
Subcontracts |
Subcontracts |
X |
Subcontracts audit |
X |
Subcontracts update |
X |
Subcontracts update audit |
X |
Users |
User roles |
X |
User roles audit |
X |
User deactivation |
X |
User deactivation audit |
X |
