Supported Oracle Generative AI APIs
When you configure an export, import, or lookup using the form view designed for the Oracle Generative AI connector, the following API operations are supported:
You can also create a composite endpoint for this application. For more information, see Application-specific (simple) forms.
Resource
API endpoint
Export
Import
Agent
Get agent
X
List agents
X
Moves an agent into a different compartment within the same tenancy
X
Create agent
X
Delete agent
X
Update agent
X
Agent endpoint
Get agent endpoint
X
List agent endpoints
X
Moves an endpoint into a different compartment within the same tenancy
X
Create agent endpoint
X
Delete agent Endpoint
X
Update agent endpoint
X
Chat result
Creates a response
X
Data ingestion job
Get data ingestion job
X
List data ingestion jobs
X
Create data ingestion job
X
Delete data ingestion job
X
Data source
Get data source
X
List data sources
X
Create data source
X
Delete data source
X
Update data source
X
Dedicated AI cluster
Get dedicated AI cluster
X
Moves a dedicated AI cluster into a different compartment within the same tenancy
X
Create dedicated AI cluster
X
Delete dedicated AI cluster
X
Update dedicated AI cluster
X
Dedicated AI cluster collection
List dedicated AI clusters
X
Embed text result
Produces embeddings
X
Endpoint
Get endpoint
X
X
Create endpoint
X
Delete endpoint
X
Update endpoint
X
Generate text result
Generates a text response
X
Knowledge base
Get knowledge base
X
List knowledge bases
X
Moves a knowledge base into a different compartment within the same tenancy
X
Create knowledge base
X
Delete knowledge base
X
Update knowledge base
X
Model
Get model
X
Moves a custom model into a different compartment
X
Create model
X
Delete model
X
Update model
X
Model collection
List models
X
Session
Get session
X
Create session
X
Delete session
X
Execute session
X
Update session
X
Summarize text result
Summarize the input text
X
Work request
List work request
X
Get work request
X
List work requests
X
Cancel work request
X
Work request error
List work request errors
X
Work request Log entry
List work request logs
X
Was this article helpful?
0 out of 0 found this helpful
