Set up a connection to Dicks Sporting Goods DropShip
Start establishing a connection to Dicks Sporting Goods DropShip in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    - or-
    -or-
In the resulting EDI trading partners list, select Dicks Sporting Goods DropShip AS2 or Dicks Sporting Goods DropShip FTP.
Supported Dicks Sporting Goods DropShip X12 documents
The supported X12 document types for the Dicks Sporting Goods DropShip trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Ship notice - 856
  • Inventory Inquiry/Advice - 846
Was this article helpful?
0 out of 0 found this helpful
