Set up a connection to Home Depot
Start establishing a connection to Home Depot in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    –or–
    –or–
In the resulting EDI trading partners list, select Home Depot AS2 or Home Depot FTP.
Supported Home Depot X12 documents
The supported X12 document types for the Home Depot trading partner are listed below:
Home Depot
Home Depot Domestic
Home Depot CommerceHub
  • Purchase order - 850
  • Invoice - 810
  • Ship notice - 856
  • Inventory Inquiry/Advice - 846
  • Payment order or Remittance advice document - 820
  • Credit/Debit Adjustment - 812
  • Ship notice - 856
  • Text Message - 864
  • Invoice - 810
  • Ship notice - 856
  • Invoice - 810
