Start establishing a connection to Sportsmans Guide in either of the following ways:
–or–
–or–
In the resulting EDI trading partners list, select Sportsmans Guide AS2 or Sportsmans Guide FTP.
The supported X12 document types for Sportsmans Guide trading partner are listed below:
Purchase order - 850
Invoice - 810
Ship notice - 856
Inventory Inquiry/Advice - 846
Purchase order acknowledgement - 855
Purchase order change request - 860
Purchase order change acknowledgment/request - 865
