Set up a connection to Zappos
Start establishing a connection to Zappos in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    –or–
    –or–
In the resulting EDI trading partners list, select Zappos AS2 or Zappos FTP.
Supported Zappos X12 documents
The supported X12 document types for the Zappos trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Purchase order acknowledgement - 855
  • Ship notice - 856
  • Purchase order change request - 860
Was this article helpful?
0 out of 0 found this helpful
