Set up a connection to Dillards
Start establishing a connection to Dillard in either of the following ways:
  • After you sign in to your integrator.io account, on the My integrations page, click Create and select Connection from the drop-down options.
    –or–
    –or–
In the resulting EDI trading partners list, select Dillards AS2 or Dillards FTP.
Supported Dillards X12 documents
The supported X12 document types for the Dillards trading partner are listed below:
  • Purchase order - 850
  • Invoice - 810
  • Ship notice - 856
  • Purchase order change request - 860
