Set up a connection to AIs Sporting Goods
Start establishing a connection to AIs Sporting Goods in either of the following ways:
    – or –
    – or –
Select AIs Sporting Goods AS2 or AIs Sporting Goods FTP in the EDI trading partners list.
Supported AIs Sporting Goods X12 documents
The supported X12 document types for the AIs Sporting Goods trading partner are listed below:
  • Invoice - 810
  • Inventory Inquiry/Advice - 846
  • Purchase order - 850
  • Purchase order acknowledgement - 855
  • Ship notice - 856
  • Purchase order change request - 860
