Set up a connection to Bass Pro Shops
Start establishing a connection to Bass Pro Shops in either of the following ways:
    – or –
    – or –
Select Bass Pro Shops AS2 or Bass Pro Shops FTP in the EDI trading partners list.
Supported Bass Pro Shops X12 documents
The supported X12 document types for the Bass Pro Shops trading partner are listed below:
  • Invoice - 810
  • Inventory Inquiry/Advice - 846
  • Purchase order - 850
  • Ship notice - 856
  • Purchase order change request - 860
