Set up a connection to Anchor Distributors
Start establishing a connection to Anchor Distributors in either of the following ways:
    – or –
    – or –
Select Anchor Distributors AS2 or Anchor Distributors FTP in the EDI trading partners list.
Supported Anchor Distributors X12 documents
The supported X12 document types for the Anchor Distributors trading partner are listed below:
  • Invoice - 810
  • Purchase order - 850
  • Purchase order acknowledgement - 855
  • Ship notice - 856
