Set up a connection to Academy Sports & Outdoors
Start establishing a connection to Academy Sports & Outdoors in either of the following ways:
    – or –
    – or –
Select Academy Sports & Outdoors AS2 or Academy Sports & Outdoors FTP in the EDI trading partners list.
Supported Academy Sports & Outdoors X12 documents
The supported X12 document types for the Academy Sports & Outdoors trading partner are listed below:
  • Invoice - 810
  • Purchase order - 850
  • Ship notice - 856
  • Product Activity Data report - 852
