Set up a connection to Scheels
Start establishing a connection to Scheels in either of the following ways:
    – or –
    – or –
Select Scheels AS2 or Scheels FTP in the EDI trading partners list.
Supported Scheels X12 documents
The supported X12 document types for the Scheels trading partner are listed below:
  • Invoice - 810
  • Credit/Debit Adjustment - 812
  • Inventory Inquiry/Advice - 846
  • Purchase order - 850
  • Purchase order acknowledgement - 855
  • Ship notice - 856
  • Purchase order change request - 860
