Set up a connection to C&S Wholesale
Start establishing a connection to C&S Wholesale in either of the following ways:
    – or –
    – or –
Select C&S Wholesale AS2 or C&S Wholesale FTP in the EDI trading partners list.
Supported C&S Wholesale X12 documents
The supported X12 document types for the C&S Wholesale trading partner are listed below:
  • Grocery Products Purchase Order - 875
  • Grocery Products Invoice - 880
