Start establishing a connection to Target DVS in either of the following ways:
– or –
– or –
Select Target DVS AS2 or Target DVS FTP in the EDI trading partners list.
The supported X12 document types for the Target DVS trading partner are listed below:
Inventory Inquiry/Advice - 846
Purchase order - 850
Purchase order acknowledgement - 855
Ship notice - 856
Purchase order change request - 860
Purchase Order Change Acknowledgement/Request - 865
