Set up a connection to McKesson
Start establishing a connection to McKesson in either of the following ways:
    – or –
    – or –
Select McKesson AS2 or McKesson FTP in the EDI trading partners list.
Supported McKesson X12 documents
The supported X12 document types for the McKesson trading partner are listed below:
  • Invoice - 810
  • Purchase order - 850
  • Purchase order acknowledgement - 855
  • Ship notice - 856
