Set up a connection to Mardel
Start establishing a connection to Mardel in either of the following ways:
    – or –
    – or –
Select Mardel AS2 or Mardel FTP in the EDI trading partners list.
Supported Mardel X12 documents
The supported X12 document types for the Mardel trading partner are listed below:
  • Invoice - 810
  • Purchase order - 850
  • Ship notice - 856
