Set up a connection to UNFI
Start establishing a connection to UNFI in either of the following ways:
    – or –
    – or –
Select UNFI AS2 or UNFI FTP in the EDI trading partners list.
Supported UNFI X12 documents
The supported X12 document types for the UNFI trading partner are listed below:
  • Invoice - 810
  • Application advice - 824
  • Purchase order - 850
  • Purchase order acknowledgement - 855
  • Ship notice - 856
