Set up a connection to Acme Tools
    –or–
    –or–
Select Acme Tools AS2 or Acme Tools FTP in the EDI trading partners list.
Supported Acme Tools X12 document types
The supported X12 document types for the Acme Tools trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase order
  • 855 - Purchase order acknowledgement
  • 856 - Advance ship notice (ASN)
