–or–
–or–
Select Bed Bath and Beyond AS2 or Bed Bath and Beyond FTP in the EDI trading partners list.
The supported X12 document types for the Bed Bath and Beyond trading partner are listed below:
810 - Invoice
816 - Organizational Relationships
850 - Purchase Order
856 - Advance Ship Notice (ASN)
860 - Purchase Order Change Request - Buyer Initiated
864 - Text Message
