Set up a connection to Chewy
    –or–
    –or–
Select Chewy AS2 or Chewy FTP in the EDI trading partners list.
Supported Chewy X12 document types
The supported X12 document types for the Chewy trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 855 - Purchase Order Acknowledgment
  • 856 - Advance Ship Notice (ASN)
  • 860 - Purchase Order Change Request - Buyer Initiated
