Set up a connection to Chewy CA
    –or–
    –or–
Select Chewy CA AS2 or Chewy CA FTP in the EDI trading partners list.
Supported Chewy CA X12 document types
The supported X12 document types for the Chewy CA trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 855 - Purchase Order Acknowledgment
  • 856 - Advance Ship Notice (ASN)
  • 860 - Purchase Order Change Request - Buyer Initiated
