–or–
–or–
Select Family Dollar AS2 or Family Dollar FTP in the EDI trading partners list.
The supported X12 document types for the Family Dollar trading partner are listed below:
810 - Invoice
812 - Credit/Debit Adjustment
850 - Purchase Order
852 - Product Activity Data
855 - Purchase Order Acknowledgment
860 - Purchase Order Change Request - Buyer Initiated
