Set up a connection to Boscovs
    –or–
    –or–
Select Boscovs AS2 or Boscovs FTP in the EDI trading partners list.
Supported Boscovs X12 document types
The supported X12 document types for the Boscovs trading partner are listed below:
  • 810 - Invoice
  • 850 - Purchase Order
  • 856 - Advance Ship Notice (ASN)
