–or–
–or–
Select Burlington AS2 or Burlington FTP in the EDI trading partners list.
The supported X12 document types for the Burlington trading partner are listed below:
810 - Invoice
832 - Price/Sales Catalog
846 - Inventory Inquiry/Advice
850 - Purchase Order
856 - Advance Ship Notice (ASN)
860 - Purchase Order Change Request - Buyer Initiated
